It's always difficult to set up ASIO4ALL configuration without a direct access to the ASIO config panel.
In general, I think that would be a great addition to add an access to the selected DAC/ADC ASIO config panel from Multi-Instrument's DAC or ADC device settings faceplate.
Do you think this is doable ?
Access to ASIO COntrol panel from DAC or ADC Faceplate
Re: Access to ASIO COntrol panel from DAC or ADC Faceplate
Thanks for the suggestion! It will be added in the coming new version.
It has been included in the new release V3.9.7.0 which is now available for download. Thanks!
It works in Build 3.9.7 !
Thank you! I really nice addition.
Reverted back to 3.9.4
ASIO calibration is grayed out and cannot be changed.
which ASIO driver was used when [Setting]>[Calibration]>"Others/ASIO" is grayed out? Is it miniDSP ASIO driver?
If "Others/ASIO" is grayed out when a particular ASIO driver is selected, it usually means that under that ASIO driver, the input gain is somehow still adjustable through "mixer" and the corresponding mixer gain percentage options will be enabled. Calibration should be done with respect to those options.
Hi VirtinsTech,
Yes. It is exactly the miniDSP ASIO driver.
I will try to calibrate according to your advice.
