LCR Issue
Posted: Wed May 20, 2015 6:06 am
by dennisr
When I try to run an LCR measurment (using the default template) I get a 'Buffer Size Exceeded' message. Everything else is working ok. Can you let me know what I need to chagne to fix?
Windows 8.1
VTDSO2810E
MI 3.4
Re: LCR Issue
Posted: Fri May 22, 2015 9:24 am
The LCR meter configuration, by default, is for sound card based measurement. If you change [Setting]>[ADC Device] and [DAC Device] to sound card, it will work.
If you want to use DSO-2810E instead, you can download the configuration files and note from http://www.virtins.com/LCR_using_VT-DSO_2810E-2820E.zip.
By the way, MI3.4 has been upgraded to MI3.5. You can download it from www.virtins.com/MIsetup.exe. The downloaded version defaults to use sound card for ADC and DAC. You can change to use VT DSO-2810E via [Setting]>[ADC Device] and [DAC Device].
