Slow UI response for large FFT size
suktan
Post by suktan »
Hello Virtins team,
I downloaded the trial version and evaluating the software. One thing I notice is that the UI response will be very slow for large FFT (> 256k). Is it expected?
Thank you!
Re: Slow UI response for large FFT size
In our test on a DELL XPS 8900 desktop computer (Intel Core i7-6700 CPU@3.4GHz, 8GB RAM, 64-bit Windows 10), the screen refresh rate is 0.9 second/frame when [FFT Size] = 262144. The trigger mode is set to AUTO so as to eliminate any delay caused by not-satisfying the specified trigger condition. The sampling duration (Oscilloscope Frame Width) is set to 10 ms to make sure the delay is not caused by sampling duration.
suktan
Post by suktan »
Thank you.
