I want to obtain damping ratio from the transform function. What should I do with the DDP/UDDP?
Thank you.
Obtaining damping ratio from transfer function
Re: Obtaining damping ratio from transfer function
The free vibration decay curve method requires MI full package. To enable damping ratio measurement using this method, right click anywhere within the oscilloscope window and select [Oscilloscope Processing]>"Damping Ratio", the corresponding DDPs are DampingRatio_A and DampingRatio_B.
In the half-power method, the damping ratio can be derived using ([BandWidthHighLimit_A(Hz)]-[BandWidthLowLimit_A(Hz)])/2/[f1Freq_A(Hz)] for Channel A. This formula can be used to define a UDDP.
I need that for the spectrum analyzer in transfer function mode. I am using a shaker instead of an impact hammer to excite the device. Hence, I want to get peak freq and 3dB bandwidth in DDP for the transfer function.
