9. A UDDP can be defined as the Crest Factor using that formula, e.g. [Max_A(EU)]/[RMS_A(EU)]
10. Set the Spectrum Analyzer in Cross-correlation mode and get the time delay value through the DDP: PeakCCFTimeDelay_AB(s)
11. Will be provided in the coming new version.
Whish list
Re: Whish list
(Sorry for not answering before, I was quite overloaded with work)
If you can add all that, that would be AWESOME !
Re: Whish list
MI 3.9.5 has been released with all the accepted suggestions here. Thanks!
Re: Whish list
Awesome !VirtinsTech wrote:MI 3.9.5 has been released with all the accepted suggestions here. Thanks!
Re: Whish list
32-bit is now supported in MI 3.9.6.1.RJA4000 wrote: 7. 32 bits PCM format support would be welcome
