Analysis from file resets the panel settings (3.9.8.1)
Postby RJA4000 » Sun Aug 06, 2023 5:21 pm
Hello again
When I open a wav file for analysis, the Oscilloscope and FFT format and selected parameters are all reset.
Would there be a way to make this optional ?
I understand the Sampling has to be adapted to the file format.
But why to loose the display and FFT settings ?
Re: Analysis from file resets the panel settings (3.9.8.1)
Postby VirtinsTech » Thu Aug 10, 2023 4:17 pm
We will improve this in the near future. Thanks!
Postby RJA4000 » Fri Aug 11, 2023 6:41 pm
Postby VirtinsTech » Mon Aug 28, 2023 2:10 am
FYI
In the coming new version MI V3.9.9.0, two menu items have been added:
(1) [File]>[Open with Current Panel Setting]
(2) [File]>[Import with Current Panel Setting]
In Device Test Plan, an option has been added to Instruction "LDF" to allow loading a file with the current panel setting.
In the Automation API, LoadFileWithCurrentPanelSetting() has been added.
Postby RJA4000 » Mon Aug 28, 2023 2:26 am
That will help me a lot !
I'm working on a lot of static file analysis right now.
Postby VirtinsTech » Sun Sep 17, 2023 1:50 am
MI 3.9.9.0 has been released.
Postby RJA4000 » Sun Sep 17, 2023 10:02 pm
I see that.
I'm using it and already, I can tell that the import of Band frequencies is a game changer for me !
Same for the capacity to analyze from a file without disturbing the Pannel settings !
Thanks 1000 times already
(the rest, I didn't go through it yet)
Return to Wish Lists
Users browsing this forum: No registered users and 8 guests
