Hello again
When I open a wav file for analysis, the Oscilloscope and FFT format and selected parameters are all reset.
Would there be a way to make this optional ?
I understand the Sampling has to be adapted to the file format.
But why to loose the display and FFT settings ?
Analysis from file resets the panel settings (3.9.8.1)
Re: Analysis from file resets the panel settings (3.9.8.1)
We will improve this in the near future. Thanks!
FYI
In the coming new version MI V3.9.9.0, two menu items have been added:
(1) [File]>[Open with Current Panel Setting]
(2) [File]>[Import with Current Panel Setting]
In Device Test Plan, an option has been added to Instruction "LDF" to allow loading a file with the current panel setting.
In the Automation API, LoadFileWithCurrentPanelSetting() has been added.
That will help me a lot !
I'm working on a lot of static file analysis right now.
MI 3.9.9.0 has been released.
I see that.
I'm using it and already, I can tell that the import of Band frequencies is a game changer for me !
Same for the capacity to analyze from a file without disturbing the Pannel settings !
Thanks 1000 times already
(the rest, I didn't go through it yet)
