MI Crashes
PostPosted: Sun Feb 26, 2017 12:08 pm
by vincer
When I load the attached PSF MI immediately crashes. Also the Signal Generator window is so wide it extends across three monitors and it cannot be made smaller unless it is closed and re opened. See the attached files
Re: MI Crashes
PostPosted: Tue Feb 28, 2017 10:42 am
Could you re-attach the screenshot?
Re: MI Crashes
PostPosted: Fri Mar 03, 2017 10:50 am
by vincer
Here is the screen capture. Open in Paint and expand to right to see entire image.
Re: MI Crashes
PostPosted: Fri Mar 03, 2017 7:43 pm
sorry, still cannot see the attachment.
Re: MI Crashes
PostPosted: Sat Mar 04, 2017 2:43 pm
by vincer
I have uploaded it to dropbox.com and sent you a link via email to: support@virtins.com
Re: MI Crashes
PostPosted: Thu Mar 16, 2017 1:31 am
by vincer
Hey Virtins, where are we with this issue?
Re: MI Crashes
PostPosted: Thu Mar 16, 2017 3:29 pm
Thanks for this bug report (see the screenshot you sent through email below).
We are working on this and will update the software together with other minor updates in about two weeks.
Re: MI Crashes
PostPosted: Mon Apr 03, 2017 11:51 pm
This issue has been resolved in Version 3.6.0.5 which can be downloaded from: http://www.virtins.com/MIsetup.exe. The following screen shot shows two instances of Multi-Instrument running on two different monitors with different screen resolutions.
