Page 2 of 2
Re: Topping ASIO driver - Buffer size exceeded
PostPosted: Tue Nov 08, 2022 5:26 am
Thanks for the information. There is another dll called SoundCardASIODAQO1.dll which is exact the same as SoundCardASIODAQO.dll. Please update that one as well and see if the debugging information pops up. Thank you very much in advance!
PostPosted: Thu Nov 10, 2022 2:03 pm
Now I see something
2022-11-10 06_58_33-C__VIRTINS Multi-Instrument 3.9_MIs.exe.png (3.74 KiB) Viewed 76125 times
I have exactly the same error with the Topping driver and the Fiio driver.
I may change the "preferred size" by setting the driver's buffer size directly.
PostPosted: Thu Nov 10, 2022 6:05 pm
Thanks a lot for the information. It definitely helped. Could you please try this updated one at: https://www.virtins.com/FileDelivery/So ... IODAQO.dll
PostPosted: Fri Nov 11, 2022 3:46 am
Now that works !
For both: the Topping and the Fiio
PostPosted: Fri Nov 11, 2022 7:06 am
The fix has been included in the new release V3.9.7.0 which is now available for download. Thanks!
PostPosted: Sun Nov 13, 2022 7:21 pm
I've imediately had it at work.
See here: https://www.audiosciencereview.com/foru ... st-1370717
