small inaccuracy of riaa compensation
Re: small inaccuracy of riaa compensation
Postby VirtinsTech » Mon Nov 11, 2024 5:36 pm
The configuration for each instrument remains unchanged unless a Panel Setting File (PSF) is loaded. Different PSFs may contain specific configurations; for example, one PSF may be set up for RIAA playback frequency compensation, while another is for Wow & Flutter frequency compensation.
Postby morillon » Tue Nov 12, 2024 6:14 am
I don't really understand what you're saying... because apart from in rare cases (test discs with tracks without RIAA), it seems to me there is no reason to remove the RIAA...in fr , thd , imd, crosstalk....w&f...
morillon
Postby VirtinsTech » Tue Nov 12, 2024 10:57 pm
In this case, you can configure a "Hot Panel Setting Toolbar" specifically for turntable measurements, with the RIAA frequency compensation file selected in each PSF in the toolbar, via [Setting] > [Configure Hot Panel Setting Toolbar].
Previous
Users browsing this forum: No registered users and 17 guests
