2 Small bugs (3.9.8.1)
Postby RJA4000 » Fri Aug 11, 2023 6:46 pm
2 small bugs:
1/ When I change frequency in generator, it happens often that the application crashes (closes without notice)
2/ Changing the number of points is quite long:
You have to type one figure then click again on the field, then go to the end then type the second figure
and so on.
Re: 2 Small bugs (3.9.8.1)
Postby RJA4000 » Fri Aug 25, 2023 8:23 pm
A third one:
When I have complex formula in UDDP (including LOG10 function), MI may crash if there is no signal at the input.
Postby VirtinsTech » Sun Aug 27, 2023 3:24 pm
Thanks for the bug reports.
1) unable to reproduce
2) solved in the coming V3.9.9.0
3) unable to reproduce
Postby RJA4000 » Mon Aug 28, 2023 2:24 am
Thanks for 2) already ;-)
I'll try and provide more detils about the 2 other points.
I'll try to find a way to allow you to reproduce.
Users browsing this forum: No registered users and 13 guests
