Driver
Driver
Postby rppaats » Wed Jan 04, 2017 5:00 pm
lost drivers for DSO2810
Where can i find the drivers
rppaats
Re: Driver
Postby VirtinsTech » Wed Jan 04, 2017 11:09 pm
The driver of VT DSO-2810 can be found in the installed software folder\Drivers\VTUSB3\32bit or 64bit depending on your Windows version. Please refer to Section 1.3 of the hardware manual on how to install the driver.
To install the driver, plug in the USB DSO, then open the Device Manager under Windows Control Panel, right click the corresponding "Unknown device" under "Other Devices", and then select "Update Driver Software...". Manually point it to the software's installation directory\Drivers\VTUSB3\32bit or 64bit (depending on your Windows version). After driver installation, it should appear as "Virtins USB 3.0 Generic Driver" under "Universal Serial Bus Controllers" in the Device Manager.
Re: Driver
Postby VirtinsTech » Wed Feb 15, 2017 2:01 pm
Just an update, the driver for the second generation VT DSOs will be installed automatically even without the presence of the VT DSO hardware when installing the latest version 3.6.0.3 of Multi-Instrument (http://www.virtins.com/MIsetup.exe, released a few days ago).
Users browsing this forum: No registered users and 13 guests
