MI,MIs, MIu application EXE files start up
What are the differences between the MI, MIs, MIu EXE application files.
I run my MI testing set up on an laptop using windows 7 64bit. I have dowloaded the latest version 3.9
When I start the program with MI.exe the program does not load, it tries, then a blank screen flashes for a brief second and nothing happens. Starting with MIs.exe it sometimes works but after a few times the loading does not work behaving like the previous scenario. So I go back to MI.exe and it works but after a few time it does not load. I am not too sure what is happening here. When none of the above works I need to first activate MIu.exe and then load the MI.exe and it works.
Can you clarify this and it seems there may be a windows or MI setup that needs to be checked.
Thank you for your support
Joseph
Joseph
