Automation: How to load WAV in Generator ?
I don't find a way to load the generator parameter with a WAV file.
In the Automation server manual (v1.7), I read
nWaveformB
Waveform for Channel B:
0: None
1: Sine
2: Rectangle
3: Triangle
4: SawTooth
5: WhiteNoise
6: PinkNoise
7: MultiTones
8: Arbitrary (via Waveform Library File)
9: MLS
How to set it to "WAV" ?
If that doesn't work, that means that I can't call the function SetSignaGeneratorParameters
which is annoying, because I need it to set the output level...
nWaveformB
0: None
1: Sine
2: Rectangle
3: Triangle
4: SawTooth
5: WhiteNoise
6: PinkNoise
7: MultiTones
9: MLS
