FFT segments
According to calculations, for a sampling frequency Fs=192KHz and FFT size=2048 samples, the resulted Resolution=192000/2048=93.75Hz, and the FFT segments=93.
In the 2 attached pictures is presented the Bandwidth (-3dB) of the Asus Xonar Essence STX, but the measurement has been obtained in the past with an old version of M.I.
The BW FFT is mine, and I'm pretty sure that Pink Noise was used as a stimulus.
For the colored FFT, which has been obtained from the web, I don't know the stimulus used.
You could see that the number of the FFT segments=2.
All others are correct.
Why this?
Fotis
Why this?
Fotis
