Multi Instrument 3.8 - questions about Device Test Plans
I'm evaluating different softwares for audio device measurement.
I use an external soundcard with ASIO driver.
One of those tools is MI Pro 3.8. I downloaded a demo and I give it a serious try.
One of the interests of your tool is that it provides some automation.
I have quite a few questions about the Device Test Plans:
I try to measure SMPTE IMD according to level.
For that, I've build a DTP with several measruements at different levels.
But I have a few issues.
1. I created a Panel setting. I can use it in manual and it works well.
But when I call the same Panel setting from a DTP, trigger is switched back to "single" and inter frame average is set to none.
I'd like the Spectrum analyser trend to look better, just to improve readability, so some averaging helps. (Measurements are not much impacted)
Any idea why and what I could do to fix that ?
2. I selected X-Y plot on "OutputAmplitude B" for X and IMD_B (dB) for Y. Also selected X range for 100dB.
I saved my DTP with those settings, but for some reason it's always reset to Frequency A and Amplitude A, and range is also reset.
3. In DTP, I'd like to automatically save the SA graphs in Bitmap and txt at each step.
How can I specify a filename with the date in it ?
4. I want also to automatically write my Derived Data Point values to a text file.
Here, I can have the filename automatically including the date and hour
Is it possible to also include the minutes in the filename ?
5. To fill test file, the only way I found was to repeat several LOG instructions after each level measurement.
One call for each DDP
Is there a way to record all or a set of DDP with just one line in the DTP for each measurement ?
6. When the DTP is open, sometimes, while moving some DDP viewer, I minimize it.
But then, no way to retrieve it anywhere.
And sometimes, it's even not possible to do anything. I could just close all windows and the app and restart.
Is there a way to get those windows back in place without closing everything ?
7. In Spectrum Analyzer view, I'd like to move the A channel down by 20dB, to avoid overlapping of A and B and improve readability.
I can do that manually by clicking on the left of the SA, and then arrow up.
Then I save the Pannel Settings.
But that's also reset when run automatically.
Any fix ?
Let's stop here with this first batch of questions.
More to come...
Could you please help me ?
Any fix ?
More to come...
