DDP using DDC as source
Postby suktan » Mon Jan 11, 2021 2:53 pm
Is it possible to use DDC data input of DDP?
I have DDC showing energy time curve (envelop) of channel B. Can I define DDP to measure the time from a peak (first or second) to a specified energy level? This is similar to decay time measurement. A screen shot is attached.
suktan
Re: DDP using DDC as source
Postby VirtinsTech » Thu Jan 14, 2021 2:27 am
Thank you for your question.
Unfortunately no. It can only be measured manually on DDC for the current version.
Postby VirtinsTech » Thu Jan 14, 2021 3:43 pm
Looks like you are trying to measure the damping ratio, we might support this measurement in the future.
Postby VirtinsTech » Tue Feb 16, 2021 5:32 am
In case the purpose here is to measure the damping ratio, please refer to viewtopic.php?f=25&t=1257 . It can be measured together with Q factor in frequency response curve.
Users browsing this forum: No registered users and 21 guests
