Activation Code
Activation Code
Postby Testman » Thu Oct 03, 2013 11:09 am
Activation Code
I have not used my Virtins DSO2810H for a while, and had changed the hard-disk on my computer. Now when running MI program I am asked for Activation Code? shere can I find that number? hjalmar
Post at 13-4-2013 23:05
If you are using 64-bit OS, please make sure that the 64 bit driver has been installed properly. The driver is located in the software installation directory\Drivers\VTDSOH1\64bit.
Post at 17-4-2013 04:46
Re: Activation Code
Postby alison3492 » Fri Dec 26, 2014 6:23 pm
At the end I´m trying to modify the parameters of your DTP archives to use 24bits and change the windowing and signal levels, but with no success until now. Could you elaborate a bit more your explanations above for me?
You can check out our latest ccna security lab and cissp dumps exams written by our Test king to help you pass www.kumc.edu You can also purchase Florida Southern College
alison3492
Re: Activation Code
Postby VirtinsTech » Mon Jan 05, 2015 9:16 pm
Could you elaborate your question a bit ?
Return to General
Users browsing this forum: No registered users and 3 guests
