When the device has only one analog output channel, only one channel will be activated on the signal generator panel (see picture below). MultiTone is supported only under streaming mode (non-DDS), therefore the maximum sampling rate sustainable is about 5MHz (16 bits, single channel) without the oscilloscope running.
![SignalGeneratorPanelwithVTDSO-E.png](./download/file.php?id=193)
- SignalGeneratorPanelwithVTDSO-E.png (26.22 KiB) Viewed 16221 times
