Whish list
Re: Whish list
Postby VirtinsTech » Thu Nov 25, 2021 3:49 am
9. A UDDP can be defined as the Crest Factor using that formula, e.g. [Max_A(EU)]/[RMS_A(EU)]
10. Set the Spectrum Analyzer in Cross-correlation mode and get the time delay value through the DDP: PeakCCFTimeDelay_AB(s)
11. Will be provided in the coming new version.
Re: Whish list
Postby RJA4000 » Sat Jan 29, 2022 11:55 pm
(Sorry for not answering before, I was quite overloaded with work)
If you can add all that, that would be AWESOME !
Thanks !
Re: Whish list
Postby VirtinsTech » Tue Feb 22, 2022 1:36 am
MI 3.9.5 has been released with all the accepted suggestions here. Thanks!
Re: Whish list
Postby RJA4000 » Sun Jun 19, 2022 6:42 pm
VirtinsTech wrote:MI 3.9.5 has been released with all the accepted suggestions here. Thanks!
Awesome !
Re: Whish list
Postby VirtinsTech » Wed Jun 22, 2022 9:35 pm
RJA4000 wrote:7. 32 bits PCM format support would be welcome
32-bit is now supported in MI 3.9.6.1.
Previous
Users browsing this forum: Majestic-12 [Bot] and 1 guest
