calculations
calculations
Postby Testman » Thu Oct 03, 2013 9:17 am
Is it possible in device test plan to program a routine where i can input harmonics frequency(only the frequency) and from this to make math calculations on their amplitudes?(+-x
If not it could be very useful for to build IMD test....(DIM 30,100 i.e)
kind regards
sankenpower
Post at 27-10-2010 03:48
Thank you for your suggestions.
1. It is possible to obtain the amplitudes of up to 8 user specified frequencies or frequency bands using the "Energy in user defined frequency bands" function in the Spectrum Analyzer. This function can be accessed by right clicking anywhere in the Spectrum Analyzer window and then choose "Spectrum Analyzer Processing" in the pop-up menu. These 8 values will be displayed in the top part of the Spectrum Analyzer window and they can be accessed via the Derived Data Points (DDP): fBand1RMS_A(EU)~fBand8RMS_A(EU) , fBand1RMS_B(EU)~fBand8RMS_B(EU).
2. As for IMD measurements, the software provides standard SMPTE/DIN, CCIF2, CCIF3 IMD measurements. You can also define your own dual frequencies using the Multitones function of the Signal Generator and obtain their SMPTE/DIN, CCIF2, CCIF2 IMD values.
Post at 28-10-2010 20:26
Re: calculations
Postby cocolove » Fri Apr 24, 2015 8:43 pm
Please let me know when the next revision of the software is scheduled for release
cocolove
Re: calculations
Postby VirtinsTech » Fri May 22, 2015 9:30 am
MI 3.5 has been released.
Re: calculations
Postby Danansmith » Tue Mar 29, 2016 3:59 pm
I would like to see the software release and working conditions. I would have been concerned. Thanks.
popular bubble football:bubble football
Danansmith
Re: calculations
Postby MaxMackinnon » Mon Jul 16, 2018 3:53 pm
To determinations of the numbers on the math and the books are the numerical problems can calculate by the frequency. Furious are for the books in the calculations by the rushessay with every wrong numbers and symbols of the plus.
MaxMackinnon
