Re: Se Vende Yunque de 65kg
Postby sunnyshazy » Tue Mar 10, 2015 5:39 pm
Hello,
I have a DSO-2810F device and I'm trying to record a waveform of ~8MHz frequency. I can't seem to figure out how to actually record/view something at 100Mhz sampling rate. The record button is greyed out and nothing is displayed on the screen. I'm pretty new so I'm not sure if I'm missing something. Can I record a high-frequency waveform somehow?
sunnyshazy
Postby VirtinsTech » Tue Mar 17, 2015 10:53 am
Unlike the second-generation VT DSO, VT DSO-2810F does not support streaming mode. For VT DSO-2810F, the RECORD button will be enabled if you go to [Setting]>[Display] and change the Record Frame Width to 500. Then, if you click the RECORD button, it will start to record. However, the recorded data may not be continuous. In other words, there may be a gap/discontinuity between adjacent frames. If you need continuous recording, choose a second-generation VT DSOs. All second-generation VT DSO support streaming mode.
Return to Control and acquire data from Multi-Instrument through ActiveX Automation APIs
Users browsing this forum: No registered users and 26 guests
